2008 XC90 Coolant fan not coming on
ingydrummer
- Year and Model: 1996 960 2002 s80
Can someone tell me where the temp sensor is on this model? its a 3.2, Im not sure if its on the block or the thermostat housing...thanks
1996 960 2.9
2002 S80 2.9 FWD
2008 XC90 3.2 AWD
2010 XC60 T6 AWD
2002 S80 2.9 FWD
2008 XC90 3.2 AWD
2010 XC60 T6 AWD
Hi there, before you start changing any sensors try to diagnose the problem first, check if there is power going to the fan first, there should be 3 wires red should show 12 volts at all time, black is ground, and the 3rd small one should only have few volts to start the module to turn on the fan, and its only there when the car is hot or AC is running to cool it down so first do your test on a cold vehicle then take it for a ride come back and test it again with AC turned on if you have power then its your fan that is bad.
Good luck
Good luck
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
2009 Merz $550
2013 chevy 2500HD
- 1442 Views
Last post by francisp
- 502 Views
Last post by ingydrummer
- 1570 Views
Last post by Py
- 928 Views
Last post by CamZH
- 973 Views
Last post by Pilot9302
