97 Volvo850 Sluggish cruise control
I removed and repaired several damper motors on the climate control system...heating and cooling works correctly now thanks to the help received here. In the process I temporarily disconnected the cruise control bellows to gain access to a damper motor. After reconnecting the cruise control it now operates sluggish...going up a hill the speed drops significantly where before it held its speed...on level or small inclines it does fine. When first engaging cruise control it does not immediately lock in...it slowly responds so my speed is lower than wha I intended. Any suggestions? Thanks, wlutz.
- Year and Model: Many Volvos
- Been thanked: 76 times
Make sure the vacuum line to the bellows isn't cracked, pinched, or otherwise pulled off the bellows. Whatever the leak is it is small or the cruise wouldn't work at all. Unfortunately, the really small leaks are the hard ones to find. Also make sure the mount was properly replaced. As I recall it isn't real obvious how the mount works and it is possible to get it replaced incorrectly.
The cruise vacuum line is a hard plastic line for most of its routing through under the hood from the vacuum pump and I'm not real sure where it transitions to a flexible line. The hard line has historically been trouble after many years of high temperatures from the engine but since the last place the system was moved was in the cabin that is where I would start.
I had only partially disconnected the 'mount'...right where it attaches to the climate system shell with a single screw...just enough to provide some working room. So I will pursue the vacuum leak possibility first. Thanks for the help. Wlutz
- 744 Views
Last post by wlutz
- 817 Views
Last post by screwdriver
- 17 Replies
- 6452 Views
Last post by ignatz
- 2809 Views
Last post by FLXC90
- 2387 Views
Last post by Matty Moo
