Hi,
About one year ago my speed/odometer stopped working for a few minutes and then started again.
On week ago it stopped again, so I switched the engine off and started it again, the speed/odometer is working fine again since then.
Any suggestion on where to start from to locate the root cause of the problem?
Thank you
Alex
1997 940 - Speed/odometer temporary stopped working
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
When both are not working, it would suggest something from rear-end sensor to speed/odometer unit.Metallo wrote:...speed/odometer stopped working..
Drive it, and set cruise next time if fails...does cruise work?
I have no idea if this is applicable: 740/940 Instrument Cluster Repair (1991+)
Metallo
- Year and Model: XC 70 AWD 2.5 - 2006
- Has thanked: 7 times
- Been thanked: 6 times
If by cruise you mean the cruise control, my car has no cruise control.93Regina wrote:When both are not working, it would suggest something from rear-end sensor to speed/odometer unit.Metallo wrote:...speed/odometer stopped working..
Everything seemed to work fine but the odo and the speed meters.
I will wait next time, it may take another year, what I find strange is that it gets to work again once you switch the motor off/on.
Anyhow, let's see next time
Thanks
Alex
Polar 940 Turbo SW - 1997
Metallo
ABS? It is working the few times I need it, that is, in the winter with snow and ice...lummert wrote:Is ABS also not working correctly?
Alex
- 93Regina
I've never dealt with this issue, but most likely, either the ground or positive sources supplying electric motor is the issue.Metallo wrote:...odo and the speed meters..
I don't know if these +/- sources are via physical wires, or ribbon cable on back-side of board there.
Metallo
OK guys,
this morning it happened again while on my way to work, however, I noticed that hitting the dashboard just above the whole cluster it makes the odo/speed meters work again, then stop then start again and so on.
It might be a soldering issue or perhaps, a connection, so I will follow the link previously posted by 93Regina: http://www.turbobricks.com/maint.php?content=art0031
Let's see what I will find out.
Alex
Alex
Metallo
Working to remove the cluster... anybody knows the correct way to disconnect the hose that goes to the turbo gauge?
Do I simply need to pull out the plastic connector (beige color) from the gauge?
If yes, is there a specific direction I have to turn it to remove or simply pull it out?
Otherwise, should I just remove the black hose from the plastic connector?
Thank you!
Alex
Thank you!
Alex
- 2216 Views
Last post by Sixthandredline
- 2006 Views
Last post by Ozark Lee
- 3184 Views
Last post by polskamafia mjl
- 11 Replies
- 2617 Views
Last post by 98v70dad
- 925 Views
Last post by wizechatmgr
