Greetings all,
I'm trying to install a manual shifter but I can't figure out how to attach the cables to the shifter. The cables use a ball and socket type connection with the sockets on the ends of the cables and the ball ends on the shifter. Any tips for getting these connected?
95 850 Trouble Attaching Manual Shift Cables
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
- Year and Model: Many Volvos
- Been thanked: 76 times
I've never had them off of the shifter end of things but what Volvo typically does with the socket type connections is to have a tiny retainer pin that slips in toward the cable side of the socket, under the ball, to hold things in place.
polskamafia mjl
Hmm...
Looking at this diagram I don't see any retaining pins pictured. As far as I can tell the ball has to be pushed into the socket far enough for it to clip in place. No one has mentioned this being difficult in any of the M56 swap threads so I expected them to go in fairly easily.
They may just be spring loaded and simply require a good smack to get them to engage.
polskamafia mjl
Placing the socket of the cable against the ball you can use a pair of angled needle nose pliers to force the two together. The ball will then pop into the socket. It only took a matter of seconds once I figured out this method.
And now we know, thanks for providing the solution.
- greg850r
- Year and Model: a long list
- Has thanked: 5 times
- Been thanked: 26 times
I'm looking to change a shifter and don't want to force anything. I think the cables just pop off the ball part on the shifter but don't want to break anything. I thought I would ask here before forcing them to pop off.
Edit: they just pop off. I took a long 3/8 wrench, slipped it in between and they came off with little effort.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
One shot of silicon spray makes your balls happier when you waggle your lever. You auto guys just watch.
This might be over the line of MVS good taste.
- 1049 Views
Last post by NotAWrenchTurner
- 2196 Views
Last post by BlackBart
- 11 Replies
- 2315 Views
Last post by Mr. Detail
- 1689 Views
Last post by Legofan
- 35 Replies
- 5801 Views
Last post by foggydogg
