'99 S70 Front Suspension Redo
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
I am gearing up to redo the front suspension on the S70. I think I'm going all in and doing inner tie rod ends as well as outers. There are two versions of the inner tie rod ends. One is supposed to be able to distinguish between the two by verifying the manufacturer of the steering rack and checking to see whether the rack has a "4" or "5" on the "service plate." I just ordered both styles of inner and will return the ones I don't use, but can anybody provide advice on locating any markings on the rack to verify manufacturer or to locate the "service plate" and the number that is supposed to be stamped into it? Thanks
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Hi,
And i should be there too to take before/after pictures and post some here if it's ok with EShowell and friends.
Should be interesting.
- Has thanked: 311 times
- Been thanked: 818 times
IPD covers this pretty well: http://www.ipdusa.com/products/5802/113 ... 8-2004-c70
One easy way to distinguish between the TRW and the SMI racks is to look at the tie rods on the car. If they are original and say TRW on them, well then you know what you have. Same with the dust boots which are perhaps more likely to be original - look for the TRW logo. The TRW rack is more common, worth a look.
You can also tell by the shape of the cover on the main steering gear casing, I don't remember those details may have it on the computer at home.
- Has thanked: 2207 times
I seem to recall there is a molded brand name on the underside and to the rear of the steering rack. You have to view it from underneath and looking up at the back of the rack near the steering column join if I remember correctly. It may be covered in gunge so clean it off. I looked on our 98 XC a couple of years ago to check and recall it being difficult to see. I'm also sure I read where to look on line somewhere, but can't recall, it may have been on MVS. The chassis plate will tell you what was originally fitted, but it may not be what is on there after all this time.
Good luck!
Neil
Good luck!
Neil
- 872 Views
Last post by Steve H
- 12 Replies
- 2233 Views
Last post by harryhendo
- 11 Replies
- 1886 Views
Last post by WhatAmIDoing
- 1173 Views
Last post by kallekula
- 548 Views
Last post by Paul1963
