2006 XC90 Air will only blow cool at best
My XC90 has 134,800 miles. V8 AWD. Air started taking forever to cool in hot weather. Took to shop and they said all OK. Still does not work properly unless on Interstate at 70 MPH. Added refrigerant and no change. Any thoughts?
Check your cooling fan if its working properly, also have some one with experience and tools to check your refrigerant level as too much is also a problem.
Good Luck
Good Luck
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
2009 Merz $550
2013 chevy 2500HD
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The interstate thing is because highway speed manages to remove the heat from the condenser in front of the car. Meaning as mentioned the radiator fan doesn't turn fast enough - check out firstly the module that sits near the fan motor
https://www.matthewsvolvosite.com/forums ... 10&t=69401
- 1177 Views
Last post by doa202
- 1143 Views
Last post by Talviomena
- 13 Replies
- 3580 Views
Last post by erikv11
- 16 Replies
- 4766 Views
Last post by coded9
- 755 Views
Last post by FCPEURO
