No start… Initially thought In-tank fuel pump, but it was throwing a code for the CPS. Replaced cps this afternoon and all went well. There are no longer any codes stored in the obd system. Anyways...back to fuel pump because it still wont start.
If I jump power to fuse 4 I can get it to start but once I remove power it shuts off. I have 3/4 tank of gas so I am confused. If in tank pump is bad, shouldn't the car start and drive with 3/4 full tank?? Moreover, if I can start the car while supplying power to fuse #4 what's happening? Fuel relay is new, as well as fuel filter. Thoughts?
..oh yeah, fuse is good (#4, #6, and 25amp near ignition coil)
1990 Volvo 240 Fuel pump?
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Code can be falsely triggered when fuel side is the issue...FPR...electrical issue, etc.mhgreen wrote:...throwing a code for the CPS...
I'll have to re-look at wiring diagram, but iirc, fuse 4 powers up several items.
I would pull Fuel Relay, and send current thru terminal that feeds fuse 4.
Nashsurecanpaint
- Year and Model: 1990 240
- Been thanked: 2 times
I'm having the same problem it sounds like. I've also posted my question in the forum. Please share any information you get. We might just have the exact same problem.
- 609 Views
Last post by 93Regina
- 42 Replies
- 12029 Views
Last post by Maestrours
- 5062 Views
Last post by wizechatmgr
- 943 Views
Last post by maverill
- 508 Views
Last post by cordobe
