Had to refill tranny fluid after cooler line came loose. Don't think I have overfilled. But getting leaks. I checked everywhere for engine oil leaks, and no engine oil is being lost. Now, looking if this is a tranny leak.
940 tranny has a vent tube (top side torque convertor), does the 850 have one? it is usually on top.
1997 855 Transmission Oil...is there a vent tube if overfill
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
- Been thanked: 504 times
In the cooler return line where it enters the transmission's top part.
I mentioned it in the DIY ATF Cooler lines rebuild DIY.
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
The vent tube is on top of the transmission. You can check the level of the transmission with the dip stick if you suspect its over full.
Its near the cooler hoses not in them.
- Has thanked: 311 times
- Been thanked: 817 times
Nice pic. +1, yes there is a vent tube, it connects directly into the trans casing. The vent tube and the cooler lines are located close together but basically have nothing to do with each other.
