1998 s70 tape around spark plug cover
I'm starting to now do all my own work when I can and I lifted up the spark plug cover and found a little oil underneath and it looks like the seal to the oil cap is bad, but I just wanted to check that no oil was leaking under the spark plug cover so lifted up a couple of the covers and found them wrapped in black tape which is crumbling to peices! Why would a garage have done that? as I had a garage do my last service and what reason would be there for wrapping the covers in tape?
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
Replacing the cap is always a good thing on these cars. I would also check the PCV system to see if it has any problems. Sealing off a pressure relief could cause other problem you don't need.
The tape is just a mystery that may not be solved unless you can get a straight answer from the service person. A guess would be that is a way to keep oil from entering the plugs instead of fixing the problem.
It's great that you want to do your own work. It can save a lot and allow you to do more maintenance. Good information in this forum. Just ask and someone will know the answer.
Shane
Shane
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
Thanks Shane, I did think maybe they put tape there to stop oil but that's abit of a shoddy fix! especially as they didn't mention it to me? but it looks like duct tape wrapped around the plastic part of the spark plug cover and its obviously rock hard now from the heat and is disintegrating into pieces, but was curious if its a known temporary fix for anything but am going to remove all the tape as its not meant to be there.obayha wrote:Replacing the cap is always a good thing on these cars. I would also check the PCV system to see if it has any problems. Sealing off a pressure relief could cause other problem you don't need.
Shane
Took all that shoddy tape off, cleaned up the covers and hoovered inside the spark plug holes as bits had come off and just fired up the car to check everything ok. This is the sort of thing that makes you want to do your own work as at least you know your not going to do dodgy fixes!
obayha
I would still do the glove test or balloon test on the PCV system, as a leaking oil cap can be an indication of problems, other than old cap.
Don't waist money on aftermarket caps. Go blue box and save some time. I don't know how I know that.
Shane
How many miles on your '98?
Shane
1998 V70 T5 331,000
Coming up to 140,000.obayha wrote:I would still do the glove test or balloon test on the PCV system, as a leaking oil cap can be an indication of problems, other than old cap.
Don't waist money on aftermarket caps. Go blue box and save some time. I don't know how I know that.![]()
Shane
I have an oil/filter change to do and would be a good time to do other jobs so you think I should test the PCV system?
And Shane, don't worry, I hear the warning about aftermarket, I avoid them where possible and try to stick with Genuine or brands like Febi, Gates, Sachs etc.
obayha
Simple test, rubber glove and rubber band over removed oil cap hole. If it inflates, it could be signs of a problem. Write ups are on here and it's not a hard job to do.
@jblackburn did a good writeup on this. Read twice and do the job once. Not read once and do the job twice or more. Don't ask.
Learning curve.
Shane
Shane
1998 V70 T5 331,000
obayha
Yep; That's rspi here on this site. Does a lot on Volvo's. He was traveling around parts of the US, but is usually on here lots.
Shane
Shane
1998 V70 T5 331,000
JRL
- Year and Model: Several
- Been thanked: 16 times
You may need someone else (ie a GOOD mechanic) to do the breather, it's not for the inexperienced and I would guess about 110% that it needs to be done ASAP, not later, but now.
You don't need to test it, if there's any amount of oil up there, it's clogged.
And, you don't replace the complete oil cap, it's just the $3.00 seal you replace.
- 3002 Views
Last post by Roger_850T
- 1223 Views
- 3874 Views
- 14 Replies
- 4684 Views
Last post by 98v70dad
- 4327 Views
Last post by erikv11
