1998 S70 O.E. Oxygen sensor brand?
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 157 times
Been thanked: 6 times
Post by Mr. Detail »
Does anyone know for a fact what the original equipment oxygen sensor is that came on my car at its birth?
I keep hearing "Bosch" but I am not really sure. Does it really matter? Is my 17 year old car smart enough to know if I don't install a Bosch sensor?
Ben850
Been thanked: 7 times
Post by Ben850 »
Yes it is.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
What Ben said!
Bosch 15097 on the front
Bosh 15062 on the rear
It really matters, yes, your car will know, and it will tell you. And don't be fooled into buying "Bosch" sensor for cheap on eBay, they are almost all counterfeits. Amazon is a good source.
Mr. Detail
Cool, I'll look for the "Bosh 15062"..... :)
Post by erikv11 »
Oops - for a 98 the connector is a different length, 15063 is the rear one, and actually that is for a turbo. I suggest look up the part number at a vendor to be certain.
Post by erikv11 »
I looked at the web pages at fcpgroton.com. Since you indicate you are replacing the rear oxygen sensor, You are going to need to look under the car, for the location of the sensor. Is it back on the middle of the car, under the cross-member that holds up the exhaust, then it is Bosch 15062. If it is much closer to the front of the car and uses only a short wire, then it is Bosch 15063.
Also, there are some "universal fit" Bosch sensors, those are also not recommended.
Disclaimer: there are lots of ways the car throws O2 sensor codes that are faults other than the sensor itself, usually vacuum or exhaust leaks.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
When you replace the rear sensor it''s a good idea to also replace the small harness
Mr. Detail
Thanks much "erikv11" for your detailed info.
JRL, doesn't the harness come with the sensor? I never buy the "universal" fit ones.
Mr. Detail
Just phoned the Volvo dealer. He told me for my application (1998, S70 base) the Volvo P/N is 9202720.
Not sure how that aprt number equates to the Bosch P/N. The dealer's price is $302.00!
Post by erikv11 »
Volvo 9202720 is a Bosch 15062. I would still eyeball it under the car to be sure your car has the long-cabled one (installed in the center of the car, like right under the center console), but the dealer is probably right.
There is a separate extension harness that Volvo sells, like this: https://www.fcpeuro.com/products/volvo- ... ar-9202715. I haven't used them but JRL certainly knows the ropes.
