This is merely speculation and not actual:
Lets say a person purchased a car, and then found out the previous owner removed the Catalytic Convertor for reason unknown. (It was cut out, and a straight pipe is in place). The new buyer lives in a state where there are no emission laws. However, new owner wants to move to a nearby state where emissions testing is required for all cars. Would new owner need to purchase a new cat, get it welded in? Is it as simple as that? Also, new owner does not have any check engine lights, and the engine light does function.
Thank you
1992 940 Turbo: Is it possible to install a Cat?
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Most likely, along with new sparks, new O2 sensor, maybe new wires and distributor cap/rotor, clean PCV system, new air filter, inspect all vacuum hoses for fitness and correctly fitted, and then maybe go to emission test site.mika wrote:speculation... purchase a new cat
Not having a check engine light light-up does not mean the O2 sensor is Good.
Redblock motors use readings from both a pre and post catalytic o2 sensor, right 93?
'97 855 N/A
'97 855 N/A
JDS60R
- Been thanked: 3 times
Yes,
You can weld in,clamp in etc. I have great success with Magnaflow units. If you mark out where you want the cat and oxy bungs I can weld them in for you . You just need to pick a cat as long as the straight pipe or we will need apiece of filler pipe. Any local welder can do it. If you can't find someone local ,let me know. I can do it over most weekends and ship it on Monday.
Retired
JDS60R wrote:Yes,
appreciate the offer. Will let you know if it comes to that.
thank to you too Regina
'97 855 N/A
'97 855 N/A
- 1062 Views
Last post by lummert
- 2208 Views
Last post by Faheyk1981
- 13 Replies
- 2429 Views
Last post by beigg
- 984 Views
Last post by smileyboy
- 1117 Views
Last post by James_A_Sousa
