1996 854 boost leak??
waterskierfl
- Year and Model: 854 Turbo
A while ago I heard a different noise than normal from the turbo as a I let off the throttle it made a fluttering sound instead of the solid pshhh sound. I am also only getting about 5 psi full throttle at about 4.5k, this boost decreases slowly to about 1 or 2 psi until it hits the next gear and then it starts at about 5psi all over again. I have had the IPD TCV with the silicone hoses for about a year now no problems. Any advice where to look for leaks or is this turbo on its last legs. It has roughly 240k on it.
- Year and Model: Many Volvos
- Been thanked: 76 times
Intercooler hoses or the intercooler itself.
Seaway
- Year and Model: 1998 V70 T5 Manual
CBV diaphragm may be torn. Remove the hose going to it and hook up a vacuum pump and see if it will hold pressure. I had a similar sounding problem on my 1998 V70. Also check the hose running from the CBV to the manifold and make sure it is connected and in good condition.
- 14 Replies
- 3093 Views
Last post by eriscentro
- 18 Replies
- 3777 Views
Last post by granite
- 1320 Views
Last post by Ozark Lee
- 18 Replies
- 5020 Views
Last post by Teddy1975
- 2220 Views
