Hello
I own a 1990 Volvo 240 DL 4 Door Sedan. I am not an actual mechanic save I can do the usual simple repairs. I am semi-retired (disability) and unable to take the car to a mechanic and have it fixed at shop prices! I have an issue with the 90 and wonder if someone could shed some light on the problem.
I installed a new fuel pump inside the tank, fuel filter and extra fuel pump next to the filter underneath the car. I also replaced the fuel pump relay. The car did sit for 11 months with gas and we have used some additives and added gas. I replaced the plugs, wires and the little 25 amp fuse on the fender wall. The car starts but will not stay running. It spits and backfires if you step on the gas and will only idle for so long. I am afraid to drive it because it will probably stop on me somewhere and need a tow.
Someone mentioned there are several or more sensors that could be causing the issue.
I was thinking of removing the catalytic converter and replacing it with a straight pipe but I was assured by a mechanic that wouldn't be causing the problem.
Any ideas from Volvo experts and or enthusiasts would be much appreciated.
Thanks
Marc
1990 Volvo 240 DL..Won't Stay Running...
Hello Marc,
Take a look at the Idle Control Valve. It is located by the intake manifold. It is kindof like the carb adjustmenet screw on a scooter. I have not adjusted mine, but have heard that there is a way to adjust it, either higher or lower.
I am sure the other guys will add their 2 cents. This is just an easy place to check out.
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
- 1503 Views
Last post by xHeart
- 13 Replies
- 2410 Views
- 912 Views
Last post by DougM
- 15 Replies
- 8768 Views
Last post by XC90Dave
- 17 Replies
- 3454 Views
Last post by SonicAdventure
