94 850 Turbo keeps blowing fuel pump relays
My 98 was just not worth fixing anymore so I bought a 94 Turbo wagon to transfer the replacement parts into. Fortunately I had a spare fuel pump relay as the one that came with it blew. It then blew my spare, and the one installed in the 98 in few minutes of run time. I had to jump pins one and three with a jumper wire. Is there a typical spot on this vehicle where the wiring shorts out?
93 850 GLT
96 850 GLT
98 S 70 GLT
88 Bertone
94 850 Turbo
96 850 GLT
98 S 70 GLT
88 Bertone
94 850 Turbo
- misha
- Has thanked: 155 times
- Been thanked: 432 times
You have some kind of short in fuel pump wiring or your fuel pump use too much current than it should.It should blow a fuse first if that's the case.Check a fuse for fuel pump...maybe somebody put a stronger one and instead of blowing fuse,it keeps blowing relays.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Immobiliser.
But...it will turn the car off in a 2-3 seconds....not few minutes.
I would replace fuel pump.
Blowing fuel pump relays,turning engine off after a few minutes....the symptoms are pointing to a bad fuel pump.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
+1 on fuel pump, if it is binding, pulls too much load, that's why there is a relay in the circuit, not just a fuse. Fuse is for the signal, relay is pump power.
Current Volvos:
The fuel pump was replaced 2 years ago. I just bought the car but it ran great for two weeks before this started. I've been working off the other things is it needed, going to scan out the wiring next.
93 850 GLT
96 850 GLT
98 S 70 GLT
88 Bertone
94 850 Turbo
96 850 GLT
98 S 70 GLT
88 Bertone
94 850 Turbo
- misha
Doesn't matter if it's just 2 years old if the tank was low on fuel all the time.That said...if it was constantly driven with around 10-15l in the tank....the pump will prematurely fail in a short time.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 311 times
- Been thanked: 817 times
He's probably thinking about the oil filter. Get a Bosch if you replace the fuel filter.cn90 wrote:Make sure your fuel filter is NOT clogged.
A new fuel filter (Mann or Mahle) is cheap, info in forum.
- misha
Mahle & Mann also makes fuel filters .
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 15 Replies
- 3103 Views
- 2017 Views
Last post by 90 Beater
- 1381 Views
Last post by Richard99
- 11 Replies
- 3884 Views
Last post by dwhite66
- 1384 Views
Last post by SuperHerman
