2000 V70 Cross Country AWD SE 167k miles.
Just bought this car for a friend and going through to fix all the issues. Power side mirrors, cruise control, and seat belt warning all don't work. Previous owner mentioned lift gate's washer also doesn't work. These are all on fuse 29 (10A) and the fuse is good (checked for 12V while with fuse plugged in). Also checked the power mirror switch connector for power (I believe blue wire but I checked all) and there is no power on any pin with key in position II. Master window control switch works perfectly.
Previous owner did replace the ECM. Not sure if ECM replacement would require any kind of sync with respect to this failing circuit. All other electronics works in the car.
Thoughts on where to chase next?
Also great if anyone knows where I can find wiring diagrams for this car. Got Volvo's EWD but its for P2s.
2000 V70XC AWD powered mirror+cruise control not working
- 5270 Views
Last post by THeOldMan
- 17 Replies
- 6476 Views
Last post by ignatz
- 32 Replies
- 9792 Views
Last post by zhenya
- 715 Views
Last post by Denwiley
- 1264 Views
Last post by RickHaleParker
