1997 850 Fuel Pump or Relay
davolvo
Year and Model: 1997 850 Sedan Base
Post by davolvo »
Hi, I believe my fuel pump just went kapoots, I will be lucky if it is the relay. My question is: is the fuel accessible through the trunk? I hope so. :?
Proud owner of a 1997 850 Sedan Base
Has thanked: 1610 times
Been thanked: 4065 times
Access panel in the trunk
See the VRD or Volvo Repair database for fuel pump discussion
stephansvolvo
Year and Model: V70 GLT 1998
Has thanked: 21 times
Been thanked: 3 times
Post by stephansvolvo »
davolvo wrote:Hi, I believe my fuel pump just went kapoots, I will be lucky if it is the relay. My question is: is the fuel accessible through the trunk? I hope so. :?
Did you find videos or tutorials on the fuel pump? The pumps are normally accessible through the trunk on the right side.
Go to you tube and search fro Robert spinner. he has step by step instructions.
Also have you ever replaced the fuel relay? I would start there as its cheap and a lot less work.
Stephan
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I would just put in a jumper wire around the relay first. The jumper pretty much tells you for sure which is bad. Just stick a wire into the socket positions that correspond with pins 15 and 87 on the relay. If everything works then the relay is bad, if it still doesn't work then chances are the pump is bad.
So long as the car is FWD and not AWD the pump assembly is easy to replace or even just replace the pump cartridge in. The latter option is the cheapest by far.
davolvo
Post by davolvo »
It turned out that I had a hole in my PVC hose. Grrrr...
davolvo
Post by davolvo »
Thanks everyone. Besides the hole in my PVC hose, I must also replace the fuel pump. I appreciate your input. It really helps me when communicating with the mechanic at the garage, who is pretty awesome actually. You people are great! Thank you so much.
