2004 XC90 Brake Failure Stop Safely Light
wilsonellis
Year and Model: XC90 2004
Post by wilsonellis »
Hi,
The rear brakes were replaced on my XC90. After they were replaced, the Brake Failure Stop Safely light comes on a few minutes after I start driving. The car is new to me so I don't have much history on what happened before. It was driven several times before the brakes were replaced without the light coming on.
I suspect that it might be an issue with one or both wheel sensors but don't want to start changing parts without knowing for sure. Any suggestions for narrowing down the culprit(s) without spending a fortune at the dealer would be appreciated.
Thank you!
Vovo_merz
Year and Model: 2007 s60R
Post by Vovo_merz »
Hi there, if you are still searching for the issue first check your brake fluid level, if its low you will get that message
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
