2002 XC70 Left Drive Shaft
- flyingswede
- Year and Model: V70AWD 1998
I got a little heavy handed checking bolt on drive shaft. Sheared the bolt. Has any one had any success with an easy out
- SuperHerman
- Been thanked: 207 times
Can you pull it out as is? If so then just take a vice grip to it once it is out. You may need to loosen and/or remove a few other components and do some up down lifting of hub to get it out with the added length.
Otherwise I see no reason an easy out would not work. Thinking about it, depending on how deep it broke it is a pretty safe drill. The bolt should not be to tight and should come out easy.
- 5203 Views
Last post by SuperHerman
- 28 Replies
- 9340 Views
Last post by gingerman
- 884 Views
Last post by ddavis6900
- 199 Views
Last post by guga
- 3598 Views
Last post by bluesguys80
