I picked up a set of Canisto rims on Craigslist last summer and everytime I hit a bump the center piece rattles like crazy. Any suggestions on how to tighten it up or do I just need to get new ones?
Thanks
1998 S70 T5 Canisto Rims
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
I have had this happen: bigger rims, more rattle. Especially the dash like you mention. Easiest thing to do is do the CORRECT tire pressure. It says it on your gas tank door (34psi I think). I used to inflate my tires to the max pressure written on the tire, and boy did my head hurt (tighter suspension too).
If by "center" piece you mean dashboard, you could always find a front "dashpad" (that's what the top part of dash is called) from your salvage yard, and transplant a new one in. It has clips and they pop off after the years. Also, you can take your current pad off and see if the clip tabs are repairable, they might be. (If you need directions on dashpad removal, Robert DIYs videos for "speedometer gear replacement" and "dashpad removal" are on youtube. It is not a hard job at all.
You can always get smaller rims, or freshen up your suspension if they are due (struts)
U Pull It Auto Parts LKQ 4555 W North Ave, Chicago, IL Is only one I went to in Chicago but it was good.
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
shaker_chi
I apologize Mika. Yes, my dash rattles, but I was speaking of the center cap that goes inside the rim.
Ed
Ed
- gmh
- Year and Model: 2016 XC60 T5
- Has thanked: 28 times
- Been thanked: 22 times
I wrap duct tape (torn into narrow strips) around the center piece to have a more snug fit in the rim.
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
1969 145S (1987-91)
1973 145E (1989-90)
- 1897 Views
Last post by Volvo S80
- 1367 Views
Last post by V50M66
- 2313 Views
Last post by sleddriver
- 1241 Views
Last post by SleeStak69
- 860 Views
Last post by 850 LPT
