02 S60 STFT & STFT; What do these 2 graphs mean???
sergio
Year and Model: S60 2002
Post by sergio »
1
Normally STFT does wobble up and down. Not around 0% but in the negative zone
But sometimes it stays dead stoned, like this time.
2
The LTFT seams always dead at about 12% from the 1st second engine starts to the last when it stops. Whether idling, running, accelerating or decelerating; suddenly or slowly :(
Can anyone translate / interpret what these particular graphs are trying to tel me?
Please?
Why both show straight lines ???
ST & LT Fuel Trim
ST & LT Fuel Trim
IMG_20150710_175245 bis.JPG (217.3 KiB) Viewed 926 times
S60 2002 180K miles looks and runs like new (except when sulking)
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
Here's a pretty good explanation of short term vs long term fuel trims:
http://www.easterncatalytic.com/educati ... ostic-tool
Thought not mentioned in the article, in my experience a malfunctioning electronic throttle body can throw fuel trims out of whack as well. But you'll want to first look for air leaks/loose hose connections, then, the list of items they talk about under 'running too lean' toward the end of the article to correct a positive LTFT you are seeing that is probably the greater concern over what STFT is showing at any given moment.
