So I installed a new air filter. I had to take the stock box and cover out in order to fit the new filter. The filter is oiled, brand new. After two days of driving, the "Engine Service Required" and Check Engine light both appear. Doing the old "hold down the mileage" button, code 42 appears. Some others with the same car have said this code is invalid, and not a code at all.
Could this issue be because of the MAF, with an oil filter contamination? Any help or suggestions would be greatly appreciated.
2007 S60R New Filter, Code 42?
Get the codes pulled at autozone by OBD2 and we can go from there, other wise it can be anything also try disconnecting the battery to see if you can reset the check engine light, few times already had a light come one and reseting it would make it go away for good, its electronics and things act up from time to time
Good luck
Good luck
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
2009 Merz $550
2013 chevy 2500HD
- Been thanked: 4071 times
If you over oil a filter you can contaminate the MAF.
Stock filters belong in these cars, which don't use oil, of course.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
As above, there are posts on forums about people who removed their KN filters because the oil was getting on the MAF wire
- 865 Views
Last post by Iceman12596
- 26 Replies
- 6070 Views
Last post by SuperHerman
- 1481 Views
Last post by speedyt5
- 1012 Views
Last post by erikv11
- 2763 Views
Last post by - Pete -
