1999 V70 T5 comprehensive vacuum tube routing
Has thanked: 1610 times
Been thanked: 4068 times
Thread to document the ME7 turbo car vacuum hoses.
First the sticker under the hood....FAIL....left over from 1998, I guess.
Four connections on intake manifold
Left Banjo nut connects to PCV pipe and is hard connected with banjo bolt - runs to PTC nipple on air induction pipe to turbo
Centre Vacuum pipe connects to EVAP purge line, the other end connects to induction hose fitting above PTC nipple
Large Vacuum threaded fitting connects to brake booster line on rear of intake manifold (driver side)
Compressor Blowoff Valve fitting goes to lower fitting under PTC nipple
Turbo fittings
Boost pressure to 'red line' in Turbo Control Valve
Wastegate fitting goes to 'yellow line' on Turbo Control Valve
Blue dot line line goes to small barb fitting on intake manifold bhind brake booster connector
Corrected above - mixed up CBV and the Blue dot hose return on the Turbo Control Valve
I need to add pictures to this thread
S.Burton10
Year and Model: 1999 V70 T5
Post by S.Burton10 »
Yes pictures, please!
Bumping this thread because bad info needs to be fixed
Picture in page2 of this thread
viewtopic.php?f=1&t=84552&start=10
