I have PO500,PO755,PO705 code.
Both speeds sensors are new, PNP switch is new. Common thread seems to point to TCM. Car starts and runs great, especially after resoldering the instrument cluster. Any advise would be appreciated.
Thanks Mike
Multiple codes 1997 volvo S90
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
One might Google:mkgray59 wrote:PO500,PO755,PO705 code
P0705 Volvo
P0755 - Shift Solenoid B
Speed sensor A - (error code P0500)
Update 3 solenoids ohm out at 12.9
TSP voltage 0.5 to 5.2 volts DC while manually moving throttle.
Speed sensor on the transmission checks good as compared to old speed sensors. Pulled TCM cleaned connecters with deOxit. Reinstall still the same codes.
I believe its the TCM. Any thoughts?
17yearsofboost
- Year and Model: 94 850T 97 S90
Any luck? I got the 0705 after changing the pnp as well. I've been told it's still slightly out of adjustment, even though lights and ignition work fine. Did you use oem speed sensors? Sounds like one isn't communicating still. If you are getting correct coil resistance (between 10 & 15 ohms) at solenoid B, my guess is you now have a faulty solenoid itslef. Rostra transmission makes a replacement shift solenoid. New fluid and filter while you are at it.
17yearsofboost
I don't think it's the TCM honestly
- 19 Replies
- 10220 Views
Last post by Barledge
- 11 Replies
- 3730 Views
Last post by gcb50
- 1953 Views
Last post by Addswing20
- 728 Views
Last post by rspi
- 1634 Views
Last post by nico416
