1994 Volvo 850 turbo wagon wheels and tires
adriana
Year and Model: 1999 V70 AWD XC
Post by adriana »
Greetings!
I found a set of tires on Craigslist, and I can't quite figure out if they'll fit my wagon. Here are the specs from the ad:
Wheels model "Mimas" 6.5X16" bolt pattern 5x108. Compatible for S60 and V70 models.
Tires Toyo P205/60R16.
Thanks in advance!
Adriana
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
43 mm (1.7 in) is mimas offset
850 is 35mm I think?
My vote is negative
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
adriana
Post by adriana »
Thanks for your reply, but I'm confused. It seems like the offset on the 850 is 43mm? And another post in this forum also talks about the bore: http://volvoforums.com/forum/volvo-850- ... fit-60215/
I'm driving around on a spare right now, so I need to get this figured out.
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
My interceptor (17x7, 49mm off set) wheels fit just fine on my 94 850, I can't see why Mimas won't fit.
85 GLH, 367 whp
00 Insight, 72 mpg
adriana
Post by adriana »
I just looked at my actual wheel, which has the offset of 43" stamped right on there!
Has thanked: 2202 times
Been thanked: 1852 times
Just a minor point, but tire size is not right I believe. I think it should be a 205/55/16". I know the height difference will change the accuracy of the speedometer, but I don't recall the calculation to say by how much.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
I'm with Neil, that's a pretty big difference (6.2 % oversize diameter/circumference see http://tire-size-conversion.com/tire-size-comparison/). I don't like to go over 5%.
With those tires, when your speedo says 60 mph your actual speed will be almost 64.
I once ran snow tires that size on an 850 sedan, they rubbed in the wheel wells when the steering was maxed out but not at other times.
mika
Post by mika »
Youll be fine then. Worse case you go to the Mexi Used Tire Shop and dish out 30 bucks for a smaller tire.
'97 855 N/A
