1998 s70 Tie rod end boot has come loose
JRev
Year and Model: S70 20V 2.5 1998
Post by JRev »
If the boot has come away from one end (furthest away) but unsure of how long its been loose, can I reseal the boot as it isn't split, its simply come loose as the people who worked on the car before used cable ties which have snapped.
Do I need to clean/inspect or grease inside the boot?
Has thanked: 1609 times
Been thanked: 4065 times
In a warm dry environment reveal
If you drive in weather or wet/ mud/slush, then remove, clean reseal.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Add a little grease (syringe), then use telephone wire to go around the circumference of the boot.
JRev
Post by JRev »
Cheers. 8)
