Broken Exhaust Manifold Stud
Volvich
Year and Model: 1998 Volvo C70 Coupe
Post by Volvich »
Hi all,
I'm in the midst of a Head Gasket job and I broke one of the exhaust manifold studs. The writeup on tracytruesoaps (Volvo 5-cylinder: How to Replace the Head Gasket) which is for NA engines, says to remove the exhaust manifold. Mine is tubo and after a little research here I found another great writeup that doesn't require removing exhaust manifold. (http://www.atthetipwebs.com/technologyi ... gasket.htm)
You just take off the bolts attaching to the head and leave the manifold attached to turbo.
Now what's my concern. If I leave the broken stud like that, how likely you think it be a problem?
What do you think?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
It is a pain but if you remove the turbo you can double nut what is left of the stud and remove it. I had several bad studs and I bought replacements at the auto parts store. There is nothing special about them.
Volvich
Post by Volvich »
I would rather leave it if it's not likely to cause problems?
I haven't touched the other three bolts so they are tight.
Post by Ozark Lee »
You can try it but pay attention. Exhaust leaks tend to actually eat away at the manifold and the flange on the turbo. A relatively small problem can turn into a much bigger problem after the leak develops.
Volvich
Post by Volvich »
I see. I just realized that I'm only looking at undoing the rest of the three bolts, right?
There's no need to remove the turbo?
Volvich
Post by Volvich »
In case anyone is interested the car is now for sale in Los Angeles.
See the ad here: https://www.matthewsvolvosite.com/forums ... =6&t=70959
