Hello
All of a sudden, I have no low beam headlights.
The high beams work great (but for some reason, the high beam lever won't stay in the high beam position)
Does that normally happen if a relay fails?
Ideas?
Thanks
1998 S90 Both low beam headlights out
Salomons Driveway
- Year and Model: '87 740 Turbo Wagon
https://www.matthewsvolvosite.com/forums ... =1&t=51332
850 owners seem to have success with mods to the switch. You can go to your relay box and try swapping the relay with another similar one to rule out the relay. If it is the relay, they are easy to re-solder.
Tim in Dallas TX
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
This may be related to a problem I had with my 1988 Volvo 765 Turbo. There is a rectangular relay (the size of 2 standard relays) on the left side of the relay panel.
1988 Volvo 760 Turbo Wagon
- 3397 Views
Last post by THAI UNG
- 2292 Views
Last post by Vovo_merz
- 2691 Views
Last post by SuperHerman
- 559 Views
Last post by ggleavitt
- 626 Views
Last post by mandkbean
