Hi, on inspecting the underside of the car today I found that the drive shaft feels very loose (up and down not rotational i.e. not splines) were it is mounted into the hub. There is no play in the wheel bearing, or noise. does the drive shaft sit in another bearing within the back of the hub? I want to be absolutely sure before I splash out on a new hub assembly.
Thanks
Matt
2006 XC90 T6 AWD rear hub / drive shaft Topic is solved
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Which hub are you talking about, the fwd. end of the shaft at the angle gear, or the rear, at the viscous coupling? Yes, axial play in a bearing indicates wear. Search the repair database for AWD or drivetrain, specifically angle gear or bevel gear for the front viscous coupling for the rear. Also several write-ups and threads on driveshaft itself.
Current Volvos:
matt_linegar
- Year and Model: XC90 T6 2005
I'm referring to the left hand side rear transverse drive shaft and the wheel hub.
Matt
Matt
matt_linegar
Finally got round to replacing the hub a few weeks ago. Really easy job
Hadn't realised just how much noise it was making, I thought it was still the centre prop making all the noise but I was wrong. It's like driving a new car now
- 5209 Views
Last post by SuperHerman
- 2407 Views
Last post by [email protected]
- 392 Views
Last post by wuttheheeck
- 17 Replies
- 978 Views
Last post by MoVolvos
- 1924 Views
