2006 V70 2.5T. Nearing 120,000 mark
obayha
Year and Model: V70 1999 Base
Been thanked: 2 times
Post by obayha »
I am seeing in the near future a timing belt change. Have looked on here for help. Anyone have a thread to point me to? Would it be best to do water pump at same time?
Thanks for any thoughts
Shane
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Personally, on the first T-belt replacement, I would check the water pump for bearing play (and leakage of course) once I had the belt off. If it still feels snug I'd blow off the replacement until the next T-belt change. But that's just me and others may see it differently.
obayha
Post by obayha »
Thanks for the link. Looks a lot like changing a '98 TB on my old V70.
Does the crank shaft pulley need to come off for sure, or can it be snaked around like on the '98. Don't know if my little air compressor will pop it loose. Will probably do water pump, while I am in there and not need of worry for another 120,000 miles.
Best place for parts? Euro?
Shane
chrism
Post by chrism »
You can snake the belt under the crank sprocket if you remove the little plastic shield from the under side. Two 10mm bolts I believe.
As I recall FCP Euro sells a "kit" (belt, tensioner, water pump, idler pulley). It seems they don't discount their kits much compared to individual pieces. Try Partsgeek also. I'm starting to like them for their competitive prices and quick delivery. You'll probably want a new accessory serp belt also. Check the condition of that tensioner's bearing also.
GBS
Year and Model: XC70 2003, V70 2002
Post by GBS »
I've done this while I replaced the front cam seals, it's not a big job but did have a few important steps, most of which are covered in the video. One thing I noticed he didn't do was turning the belt another 90degree after aligning before taking off the belt. Maybe that was only for me doing seals but I seem to have read that they are spring loaded and this takes the tension off so they fall back in original position. I had VVT on both intake and exhaust, the video only on intake.... Maybe someone can comment on which is correct.
I tried to get the pulley off the crank shaft but was unsuccessful, that big bolt was stuck. It's not needed though so just take a small rubber cover underneath the crank pulley off and it slides out, I'd do it that way again for sure.
Its a fun job but pay attention and ask questions before rather than after, I think the 90 degree then pull back to timing is important but hopefully someone else can comment too, I've done this once. I'd replace water pump, idler and tensioner while in there, water pump means draining the radiator but that's about it. Also have you replaced serpentine belt and tensioner? if not it this might also be a good time for that....
chrism
Post by chrism »
"... I think the 90 degree then pull back to timing is important but hopefully someone else can comment too..."
If you don't remove the cam sprockets from the cam shafts then all of that VVT turning 90 deg stuff can be ignored. Put the cams and crank on their marks before removing the old belt and make sure all three are still on their marks after the new belt is installed (and make sure they all come back up on their marks each time you hand-crank the crankshaft two revs) and you'll be fine.
It's when you separate the sprockets from the cam shafts that you lose the proper alignment relationship and thus have to go through a more involved alignment procedure.
GBS
Post by GBS »
Awesome, thanks for clarifying that.
obayha
Post by obayha »
Thanks to everyone for the information. I watched the video and will probably watch again before doing. Will do serp and tensioner and all other things that may go bump down the road.
Great I can leave crank sprocket on, and I will check Partsgeek to see what they offer.
Shane
Has thanked: 1610 times
Been thanked: 4068 times
If you have been changing coolant every two years leave that OEM water pump in. They last a long time. At 15000 miles per year, replace it in 5-7 years.
obayha
Post by obayha »
abscate wrote:If you have been changing coolant every two years leave that OEM water pump in. They last a long time. At 15000 miles per year, replace it in 5-7 years.
Well I sort of changed the coolant . Up until this year, the radiator had a small leak and so I added coolant every 500 miles or so. It started leaking more, so this year I installed a new one.Now I need to remember to change the coolant every two years.
