99 V70 Intermittent AC Cut Out
JeffHicks
Year and Model: 1989 240 Wagon,
Post by JeffHicks »
I'm looking for some ideas before I go fishing on this one...
Our base 1999 V70 has recently began to intermittently do two things:
- Sometimes, with the fan running fine, the AC stops blowing cold. It might start blowing cold on its own, but if you shut the car off and start it again, the AC will be on again.
- Second - and this is a recent development - sometimes the blower fan itself just decides to not run. This seems to be completely random, not connected with the AC blowing cold, nor turning off and re-starting the car.
AC is fully charged, and when it's running it runs perfectly and blows ice cold. Everything else with the car is in tip-top shape.
So is there a "typical" issue that would bring about these two problems? What would be the first thing you guys would check? Any advice, before I start in on a process of elimination?
Thanks much!
1989 240 Wagon, 1999 V70 Base, 2002 XC70, 2005 V70 T5
JBC2565
Year and Model: 2000 V70 XC SE
Post by JBC2565 »
Search the 'AC Clutch Gap" fix. Classic sign of intermittent AC. Also people use zip ties and bread tags to fix the gap. Very well covered on the forum.
JeffHicks
Post by JeffHicks »
Thank you!
Has thanked: 1503 times
Been thanked: 3817 times
You will probably need to replace than fan pretty soon Jeff. Ypu can try opening them up, cleaning it out, and lightly oiling bearings but if you want to run the car for more than a year in climates needing either heat or cool, then replace. About 150 from IPD or Eeuro and I wrote it up recently on my 1999
JeffHicks
Post by JeffHicks »
abscate wrote:You will probably need to replace than fan pretty soon Jeff. Ypu can try opening them up, cleaning it out, and lightly oiling bearings but if you want to run the car for more than a year in climates needing either heat or cool, then replace. About 150 from IPD or Eeuro and I wrote it up recently on my 1999
Thanks man! Early warning signs are good, even if we don't like them.
The car has about 185,000 miles on it, so I'm sure the fan is getting tired.
I'm a "regular" out at our local U-Pull-It salvage yards. They charge $25 for a blower fan, so if I get lucky and find one, I might give that a try. If that one's a bum, I'll spring for the new motor.
Thanks!
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Does the blower stop running even when the A/C is off? It might be just the resistor on the blower
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
Before you install a used blower be sure to lubricate both the front and rear bearings. The front one can be a bit tough to get to but I use Tri Flow brand oil that has a tube that fits in the end of the cap and lets you better aim the hole where you need it to go.
JeffHicks
Post by JeffHicks »
Thanks for the info, guys!
Got a couple more questions here...
I'm going to head off to U-Pull-It this afternoon, in hopes of striking gold. If I find a donor car, I think I'll grab the blower motor resistor while I'm in there. Is that resistor right in there by the fan, as it is on most vehicles? Second, what year-model cars can I scavenge from? Did Volvo throw the same blower motor in 20 years' worth of vehicles, or is it for 1 or 2 years only?
Thanks!
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
'98 - '00 On the fan.
JeffHicks
Post by JeffHicks »
Thank you for the video links, RSPI. I've used that guy's videos a lot! :-)
To follow up, I now have a blower motor working! Because of time and economy, I ordered the "TYC 700163 Volvo Replacement Blower Assembly" off Amazon. $60, and free shipping. Ordered it Friday and it got here this morning (Sunday). Obviously it's not OEM, but I figured it was worth the risk.
The install was extremely easy. All screws are a T25 Torx. I removed the glove box, then the two screws that hold on the trim piece under the glove box - a total of about 10 screws. It used a flat screwdriver to remove the plug-in, and the same T25 Torx to remove the 4 screws that mount the fan to the housing. It was tight getting the old fan out, and new fan in, but no big deal. Entire thing took about 10 minutes.
I HAVE AIR!
I will address the intermittent AC issue when it's not 98 degrees outside.
Thank you, everyone!
