Hello,
Recently the dam thing triggered an Evap Code for 'small leak detected'. Could this be because of a small leak in the big air filter box?
THanks.
1998 v70 Evap Code
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
MrAl wrote:Hello,
THanks.
"big air filter box" you mean your air filter for the throttle/intake? If so, no. Evap is usually the vent system for the fuel tank if I remember correctly. HOWEVER: I have gotten this small leak code on 2 occasions: ran car too low on gas and must have let air into the system, and another time my gas cap was not tight enough. Also, another time, one of the vent hoses for the tank (by the fuel filter) severed into 2, but I had a smell of gas in that area and knew something was off. ....Fill it up, tighten gas cap, clear it, see if it comes back on.
If it really is a gas tank evap leak, there are a few resources on here about how to remedy it without removing tank.
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
- 1355 Views
Last post by Miltown
- 255 Views
Last post by Clockboy
- 553 Views
Last post by jjmtjordan
- 945 Views
Last post by bmdubya1198
- 2223 Views
Last post by matthew1
