So another rear tailgate latch not working. Read a bunch of posts but was trying not to get a new assembly unnecessarily. It wasn't an intermittent problem it just suddenly stopped working. The rear hatch dash light has been on for weeks.
I've taken the door card off and the lock is working from all points electrically/manually (has 3rd row seats) so there is power to the lock portion of the assembly. When I manually push the outside latch's interior rod the door still doesn't unlatch. There is no sound coming from the assembly so its not like it's a weak motor and not able to unlatch. I've "jiggled" the wiring harness around the door and the back pillar while holding the latch open with no joy.
I did not locate a rear fuse near the driver's side tail lights as some posts mentioned...but mine was a slightly different year. I took apart all the panels on the back drives corner so if it's somewhere else please let me know where. Like I mentioned there is power coming to the assembly because the lock actuates...
Is there a different power wire for the latch? If I knew the color scheme or had the diagram I could test voltage before I bought a new assembly (which would't fix if it was a bad connection). If not and there is no fuse then I guess I am buying one...
All help would be greatly appreciated. Thank!!
1998 V70 XC Tailgate locks not openning. Wiring diagram
bskeels
- Year and Model: 1997 Volvo 960
- Been thanked: 3 times
I suggest taking the latch out (3 bolts, plus the linkages and inside latch), pulling the electrical portion off (2 torx screws) examine inside the actual latch, if the spring is only attached at one point or not attached at all (my xc did this, as all the connection points broke) you will need a replacement. Here's what I used (a newer model type from 2001 up) like this one,
http://www.ebay.com/itm/121695307260?ss ... 1436.l2649
I unscrewed the electrical and removed straight out and swapped my electrical in.
The Fleet
2012 Ram 2500
97 Volvo 960
98 V70 AWD (208000+)
66 Volvo 122s sedan project
98 Volvo V70 XC (151,000+) parts car
08 Volvo V50 T5
"Human history becomes more and more a race between education and catastrophe" - H. G. Wells
2012 Ram 2500
97 Volvo 960
08 Volvo V50 T5
bigthicket
- Year and Model: V70 XC 1998
That's a much better price so I'll go ahead and order it. It's a daily driver so don't really want to pull out the mechanism without the replacement in hand.
bigthicket
Ok that worked but I snapped the back door key connector and a couple of the tailgate card's snaps off. 17 years in the TX heat makes all that plastic brittle. Guess I'll need to order that anti rattle kit to get the tailgate card back on. Thanks bskeels for your reply!! $30 and some sweating in cramped quarters did the trick....
difflock54
- Year and Model: V40 Nordic 2002
- Has thanked: 7 times
- Been thanked: 2 times
For your future reference you can get the electrical wiring diagrams for your model from the link below.
http://www.volvowiringdiagrams.com
- 2599 Views
Last post by legalstuff
- 23 Replies
- 4666 Views
- 595 Views
Last post by mar601
- 2020 Views
Last post by DoggyB22
- 1342 Views
Last post by yanga001
