I have done a search and looked at the posts, even before I joined. The obd2 gives me the code PO303. Not only that, the radiator blew a hole in itself. Fixed that and changed the oil (no antifreeze, etc. head gasket would appear ok from lack of oil contaminate)
It has spark. Checked it with my spark plug tester.
I did a compression test, C1 150, C2 130, C3 150, C4 150 psi. (three turns each, not sure if that is how many one is supposed to do it, I just tried to make it all the same duration)
While running I pulled the power from the #3 injector. (had problems, i.e misfire as no gas, so I figure, it is getting gas) (Whether it is a good idea, just put some Lucas deep cleaner in the tank)
While running I pulled the plug from the coil. (had problems, misfire from no spark, again, it has spark)
Engine lights comes on, then after awhile goes away, then repeat. OBD2 always reads PO303.
Car chugs or surges under load and low Mph.
I check spark, fuel, and compression. What am I missing? (besides a new car)
I need to fix this or it won't pass smog.
2001 s40 misfire cylinder 3 I'm missing the reason
dragonsong
- Year and Model: S40 2001
OK. I've passed the smog. don't know how or why. anyway, the water pump is leaking, especially after a 30-40 min drive. I get. puddle. when it cools in the puddle is bigger. easy fix?
not sure about your water pump leak but as for the miss fire, try changing those 2 coils around and see if the missfire goes to a different cylinder I had a similar problem and because in that engine one coil is responsible for 2 plugs some times only one part is working but not the other or not enough spark and if you disconnected the coil fully then you have 2 cylinders not working which makes it even worse.
Good luck
Good luck
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
2009 Merz $550
2013 chevy 2500HD
S40Colorado
- Year and Model: S40 2000
Coils, wires, plugs. * Check boots and wires for cracking and/or arching. plugs for wear
- 2864 Views
- 1314 Views
Last post by mrscullini
- 5026 Views
Last post by ifumme
- 2181 Views
Last post by precopster
- 18 Replies
- 15121 Views
Last post by LadieRed
