2005 xc70 serpentine belt tensioner
mrscullini
- Year and Model: 05 XC70, 08 XC70
- Has thanked: 1 time
couldn't find the answer after a search. there does not seem to be a bolt head in the center of the tensioner. my 2000 had a 14mm hex head that i grabbed to release the tension on the belt. how do you grab the tensioner on the '05 to release tension?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Tap with a screwdriver to remove the plastic cap. Ratchet with a handle extension on the 14mm bolt then clockwise until it stops (a good 90 degrees) to release the tension
mrscullini
thanks. i got a torx bit into the recess. using a strip it grip to turn.oragex wrote:Tap with a screwdriver to remove the plastic cap. Ratchet with a handle extension on the 14mm bolt then clockwise until it stops (a good 90 degrees) to release the tension
JRL
- Year and Model: Several
- Been thanked: 16 times
Did you ever do the axles and did it help?
mrscullini
thanks jrl. i did do the axles on sunday. it does seem to help. i haven't driven it much because i'm currently battling a haldex pump issue that just popped up.JRL wrote:Did you ever do the axles and did it help?
i've got to get it up on blocks so i can check the pump and the dem.
- 1383 Views
Last post by Faust
- 30 Replies
- 4913 Views
Last post by regent
- 14 Replies
- 3935 Views
Last post by PeteB
- 1096 Views
Last post by lrb34
- 23 Replies
- 4137 Views
Last post by bmdubya1198
