'98 V70 5 spd, base - Part ID Needed; collar near gas tank
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
While replacing the passenger-side rear brake caliper on my FWD '98 V70, non-turbo, I noticed a metal collar between the filler pipe and gas tank. It is 3/4 rusted away and the remainder has the consistency of baklava. It has some sort of band clamp around it and may originally have consisted of two halves. Anybody have any idea what this part is and what a part number may be if I need to obtain a replacement? Thanks.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- E Showell
FCP lists a "filler neck retaining sleeve" -- PN 3531428, but it appears to be only half of the part I need.
'95 855 auto (sold)
'95 855 auto (sold)
- Has thanked: 2199 times
- Been thanked: 1851 times
Hi Evan,
From Vida for a 98 V70, using the part number you give, you need 2 of these. The picture I am looking at shows the tank, then a seal/gasket (Part # 6842188), then the check valve (part # 9135119), 1 6 point socket screw (part # 986160), the 2 clamps (part # 3531428 x 2), 2 flange screws to hols the clamp together (part # 982758 x 2) then it attaches to the pipe that runs up to the filler inlet.
Hopefully that helps. If not, e-mail me and I'll try to get a picture to you or hopefully this link will get you to it:
http://www.volvopartswebstore.com/showA ... evel=11158
- E Showell
Great, Neil. Thanks.
'95 855 auto (sold)
'95 855 auto (sold)
- 834 Views
Last post by puntmeister
- 18 Replies
- 2719 Views
Last post by E Showell
- 630 Views
Last post by darrylrobert
- 357 Views
Last post by JelloBrick
- 386 Views
