1999 Volvo S70 headlight switch
asummers
Year and Model: many
Post by asummers »
Does anyone have a diagram of how the headlight switch is removed from the dash? Or, give a play by play on the removal. Trying to figure out if it is a simple process to remove or not. I am removing one from a parts car on my lunch hour and don't have access to my Vadis program here at work, and haven't removed the broken one from my car. It is great fun when you start to leave for work and turn on your headlights and the switch literally comes off in your hand. The whole front half of the switch came off, pieces and spring hit the floor!
2004 Volvo XC90 AWD - 170,000 miles
2010 Volvo XC60 AWD - 145,000 miles
1996 Volvo 850 Platinum - 201,500 miles - KILLED BY UNINSURED DEER _
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
If you access from behind (knee trim piece removed using Torx screwdriver), then push the switch out from behind.
Another technique is a tiny flat screwdriver, wrap it in some cloth and pry the switch out from the front.
Just look at the existing HL switch and you will see the tabs that hold it in the dash.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
