I have a 2001 S40 with multiple engine codes, all seem to be related to bank 1, so wondering if there is a specific part that could be the issue, i.e. ECM versus multiple sensors. Car has 190,000 miles. Operation wise it runs fine with the exception of coming to a stop and starting from a stop, when starting from a stop it will hesitate, then go after about 5 seconds, likewise when stopping at a light the RPM's will drop to like 500 the bounce up and down before settling out after about 10 seconds.
Codes I'm getting are the following P0171 - "System too lean bank 1", P0107 Manifold Abs Pressure/Barometric Pressure Low, P0128 - "Coolant Thermostat Below Regulating Temp", P0237 - "Turbo Sensor A Circuit Low", P0236 - Turbo Sensor A Circuit Range/Performance, P0131 - O2 sensor circuit low voltage bank 1/sensor 1, P0015 - Camshaft Position Timing Out - Retarded Bank 1.
Realize it may be that Bank 1 jumped time but is there a way to check that without taking everything apart. Any recommendations of where to start would be appreciated.
2001 S40 1.9T Multiple Bank 1 Problems
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Note: your motor only has bank 1, six cylinder engines are split into 1 and 2, 4s and 5s are bank 1 only.
How old is the timing belt? Is it due...past due? was the tensioner changed last time? Water pump and idlers?
Verify your timing first, that'll kill your motor if it's wrong. It may be off by only a tooth, causing the performance to degrade but not smack valves and pistons. Make sure it gets fixed, if it skipped once, it WILL skip again, but worse. Pull the upper belt cover off the cam gears, rotate the engine by hand to see if the upper marks look right. (this is just a preliminary check) Improper timing could cause all kinds of monitoring mayhem, as it will throw the mean pressures off and make the ECU try to compensate.
We'll wait for follow up
Current Volvos:
- 2062 Views
Last post by jblackburn
- 1519 Views
Last post by Slycox
- 991 Views
Last post by StupidS80
- 5182 Views
Last post by RickHaleParker
- 11 Replies
- 1059 Views
Last post by bcfischer
