1998 V70 T5M Broken Transverse Arm Mounting Bolt - Part #?
Seaway
Year and Model: 1998 V70 T5 Manual
Post by Seaway »
Last night I tried to install an IPD rear sway bar on my wagon but I didn't get very far. Per the instructions I tried to loosen the "Transverse Arm Mounting Nut (21mm)" and the bolt broke under what seemed like light pressure. I was using a regular 3/8" ratchet, so it isn't as though I was torquing on it hard.
My question is this: what is the bolt called, or what is the part number for that bolt? At this point I will likely get two of them and take the whole project to a shop where someone can put it on a lift and do it. I really don't like being all the way under the car when it is up on jack stands anyway.
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
85 GLH, 367 whp
00 Insight, 72 mpg
Seaway
Post by Seaway »
Thanks!
Seaway
Post by Seaway »
Wanted to return to this to see if anyone can help me with a way to remove the broken bolt from the transverse arm?
After it broke, I tried to remove the broken bolt, but I have not had any luck. I put a ratchet on the top of the bolt and can turn it but I can only get it up about half an inch, then it simply spins in the hole. I tried using a punch to drive it out, but it does not go. Could it be corrosion since the metals are dissimilar? Is the top of the transverse arm threaded? Any suggestions?
