fuel pump access hole cut. Pump issues
Acjlarsen
Year and Model: 2000 volvo v70xc awd
Post by Acjlarsen »
I have had a lot of trouble with my car starting rough. The cause is fuel returning to the tank after i turn the car off. I first tried putting a check valve in line after the fuel filter, that didn't work probably didn't use a high enough quality unit... Now I've tried replacing the fuel pump, but rather than dropping the tank i cut an access through the drivers side passenger floor, pulled the pump out, and realized that this car doesn't have a pump in the tank. Its a fuel pickup (mesh bag lines and fuel gauge float. I already had a actual pump ordered because i called fcp and they gave me the part number, i didn't end up getting it from them, i got it off ebay using their part number. I also verified the pump i got off ebay looked the same as what fcp and several other sites say i need. Im lost wondering where my fuel pump is and where the one way valve in this systems is. So if anyone can follow that story is there any advice?
This is the pickup i pulled out of there.
This whole i cut. Ooofda.
I got all nervous cuttin over the gas tank and about 2cm from a fuel line so i wet things down abit as i cut
The pump fcp and other places said i need for the awd. part no 9470674
Blockpartie
Year and Model: ...
Post by Blockpartie »
Wrong side. Your main fuel pump is on the passenger side, what you removed is the aux. "fuel pump" for in tank transfer.
Acjlarsen
Post by Acjlarsen »
I dont see a screw cap on the other side?
Acjlarsen
Post by Acjlarsen »
Plus my fuel gauge float is on aux pump i removed and the fuel pump i bought has it in it also.
Acjlarsen
Post by Acjlarsen »
Do i have a float in each tank?
Blockpartie
Year and Model: ...
If you don't have a fuel pump on the passenger side I'd really like to know your car ever worked in the first place.
And yes, you have a float in each side of the tank. There is only one tank as such.
Acjlarsen
Post by Acjlarsen »
Ok so i need to look around more on the passenger side for a pump.
Also, Is the one way valve in the pump?
combatkarl
Year and Model: 1997 850 GLT
Post by combatkarl »
These seem to be a good threads regarding fuel pumps in XC models.
https://www.matthewsvolvosite.com/forums ... hp?t=32192
Fuel pump replacement diy v70xc
Good luck in Brr-medji. I'm in the banana belt of SE MN. :)
Karl
1997 Volvo 850 GLT
2001 Honda Odyssey
1999 Mazda Miata
2012 Dodge Journey
1984 Honda Nighthawk S bike
Acjlarsen
Post by Acjlarsen »
Ha!
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
holy moley that is more complicated than a p80! I thought the double pump set up on the B230s was confusing until I saw this
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
