How to replace turn signal bulb inside the side mirror -PICS
Turbo_Boss
Year and Model: 2008 XC90 3.2AWD
Has thanked: 12 times
Been thanked: 2 times
Post by Turbo_Boss »
Hey Guys
Today I replace the blinker / turn signal bulb / lamp inside the side mirror.
You need to remove the mirror form the housing. In order to remove the mirror, you need to pry it out and then hinge it to one side.
As you can see in the pic, I use my fingers to pry it out. Be careful when you remove the mirror since it has it has 2 tiny wires that connect it to the defroster on the back of the mirror.
After you replace the bulb, to install again the mirror in their position, just pushed in their position and push it until you hear clicks.
Also, here is info that can help you too:
http://forums.swedespeed.com/showthread ... ignal-bulb
This is a piece of cake job
Hope this info and pics help.
THX
Isaac
2008 VOLVO XC90 3.2L AWD
2008 TOYOTA Prado 2.7L 4x4
2009 VW Jetta 2.0
