98 V70 FWD Parking Brake Not retracting on rear passenger
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
Rear right parking brake will expand when parking brake lever is pulled up but it does not retract when released (pulled down). If I by hand push the parking brake pads together... yes they will move back to their correct position. BUT without help they do not return to position.
Left side parking brake expands and retracts perfect. Does this mean I need a new parking brake cable or is their a quick fix that can be tried first or something I should look at first? I did try shooting WD40 in the exposed part of the cable at the hub. Thanks for any advise. FYI This car is a manual transmission so the parking brake is kinda important. All visible parts and pads are in good condition and have been cleaned and are not rusted or seized etc.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
Sure could be a bad cable. If 1 is bad, replace both
'00 S70, '04 S60 and the never ending quest for Stage Zero
cuhfs
Post by cuhfs »
Looks like I will replace the cable. :o
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
Has thanked: 2199 times
Been thanked: 1851 times
Parking brake cable on that side. But as you have to pull the center console to replace the cable at the parking brake lever between the front seats, it makes sense to replace both. The cables fray internally and when you pull the lever, the brake shoes will expand as you have a lot of leverage at that end. At the rotor end there is nothing that has the strength to do that so it jams on, and may eventually work it's way off. Time to replace.
