1997 850 wagon blinker assembly failed
Tobers
- Year and Model: 850 wagon, 1997
the corner blinker assembly on my daughter's 850 wagon just fell out the other day. It was dangling from the car. She duct taped it back in. The little black plastic tab that engages the spring has sheared off. Ideas? I'm guessing 18 years of heat/wear and tear caused it to fail. Thanks! Rick
- Been thanked: 504 times
Aftermarket is TYC brand, seems decent. Check ebay.
Another option is drilling tiny holes and use small telephone wires to hook it back together to body frame.
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
Rock auto used to carry them, but if the retainer spring is still in tact, you might be able to hook it to the plastic housing a different way. I did this once. I think I drilled a small hole to catch the hook.
- RussB
- Year and Model: '00 S70, '04 S60
- Has thanked: 3 times
I have upper and lower lights I'm parting out from my '96 wagon, which has V70 uppers (clear instead of yellow) and both fronts
'00 S70, '04 S60 and the never ending quest for Stage Zero
Only the v/s 70 had this issue, as the 850 has a nice spring and no tabs. I have lost 2 blinkers like this already! RSPI says in one video that "you should never pass up a turn signal at the junkyard" in his "don't be that guy" video.
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
- 431 Views
Last post by blueechosf
- 810 Views
Last post by mastercurry
- 865 Views
- 609 Views
Last post by havardbo
- 11 Replies
- 1604 Views
Last post by RBooby85
