Hello,
I recently serviced the PCV on my 99 S70 base (230k) using the FCP euro kit. I also changed all 5 spark plugs using Genuine Volvo spark plugs. Right after finishing the PCV service and changing plugs, I had difficulty starting up the car. After getting it started, billows of white smoke came out of the exhaust for about 20 minutes. The engine is also shaking terribly but the idle speed is the correct 850-900rpm. I have codes P0300 (random misfire) and p0135 (02 sensor, bank 1 sensor 1).
During the PCV install, some coolant leaked onto the alternator directly under the hose on the front left side of the engine bay. I let it dry for a day.
Additionally, one of the lower intake manifold screws and two ETM screws split in half and broke meaning they are currently missing from the engine. Battery was disconnected during repair. Pulled ignition coil wires while car was on (after install) and noticed that the two leftmost cylinders have an issue since they don't affect the idle.
Spark plug wells were swimming in unburned oil prior to the PCV service; I dried up most of the oil. Engine has never had shaking problems unless RPMs dropped below 850-900.
What's most likely - vacuum leaks or shorted out/broken ignition coils? Would the O2 sensor malfunction cause engine shake? Looking forward to any possible ideas from you all.
1999 S70 NA PCV system fix caused misfire
Clockboy
- Year and Model: 05 xc70, v70 2.5t 06
- Has thanked: 2 times
I'm not sure if a bad o2 sensor would cause a hard start and the smoke.
If I remember correctly my car continued to smoke a bit on start ups after I did the pcv and that eventually went away.
Did you remove the injectors from the rail when you did the pcv. I know some people leave them in.
If it was a hard start and two cylinders are not working maybe it's fuel/injector related. Usually when I have a seemingly new problem after finishing something it is from something I touched along the way.
I would think the missing bolts could cause vacuum issues and the vacuum issues could in turn cause the o2 sensor to fire off a code. I would definitely get the bolts back in, check all the hoses and then see how it runs.
You could also change the cops to other cylinders and see if the mis follows those two. That would rule out the unlikely event of two cops spontaneously went bad at the same time.
I hate finishing a job only to have something else fail without ever reaping the benefits of the hard work. At least give me a day to enjoy it.
Hopefully someone more knowledgeable will chime in with a more experienced perspective.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
You messed something up during pcv replacement.
Check everything,especially intake manifold gasket and vacuum lines.
Could be that those ignition coils failed or damaged during pcv system.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
kyalami321
- Year and Model: 1999 S70
I bought some used but guaranteed working ignition coils off eBay that will arrive next week Monday. I will test these and hope that they fix the problem, because refitting all that mess is such a PITA. Thank you guys for your suggestions. Glad to know the O2 system is unlikely to be the culprit; eliminates another possible piece I have to replace.
If the missing screws are near the non-working cylinders then I would get that put right. I would not expect an ETM to work unsealed and improperly mounted either.Additionally, one of the lower intake manifold screws and two ETM screws split in half and broke meaning they are currently missing from the engine. Battery was disconnected during repair. Pulled ignition coil wires while car was on (after install) and noticed that the two leftmost cylinders have an issue since they don't affect the idle.
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
This.misha wrote:You messed something up during pcv replacement.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
kyalami321
I moved some of the coils around to see if it would change, and no dice. After I get out of work I will check all vacuum lines/manifold gasket. I Will report back
Indeed, it's one lower intake manifold bolt that's near the "dead" cylinders.If the missing screws are near the non-working cylinders then I would get that put right. I would not expect an ETM to work unsealed and improperly mounted either.
Sommerfeldt
I don't think I would run the car anymore until you get the gasket checked and that bolt replaced. Also the ETM bolts... All of those should have been in place and torqed down correctly before firing it up in the first place.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
kyalami321
Ok I rechecked all my work and replaced all the bolts except two to the ETM, which are broken. No dice.
However, I remember that when I was tightening a bolt right after finishing the PCV replacement, I had forgotten to disconnect the battery. There was visible electricty and a zzzt sound when I struck my ratchet against the engine block. I obviously shorted something out, but could it be the O2 sensor and would that cause misfire through low fuel pressure?
- misha
You fried ignition coils and who knows what else.
I told you that you messed something up.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 165 Views
- 938 Views
- 20 Replies
- 3479 Views
Last post by scooterlovesvolvos3
- 12 Replies
- 6352 Views
Last post by erikv11
- 27 Replies
- 11744 Views
Last post by dono
