Hey guys, I'm replacing my front brake calipers today, and got some reman from FCP. Looks like the piston boot/seal isn't seated properly on the front right one. I'll attach a picture.
If I go ahead and install it, will it reseat itself or am I just asking for trouble?
Is there a way I can reseat the boot before I put it all back together?
New front brake caliper, bad piston seal??
futureboycolin
- Year and Model: 1996 850 Turbo Wagon
- Has thanked: 1 time
futureboycolin
Is there a way to push out the piston without an air compresser?
I reconnected the caliper to the brake line to stop it from leaking. Can I push it out using the brake pedal?
1996 855T, "Ol Burgie"
futureboycolin
Well, good news is that I reseated the piston boot.
The bad news is that I can't for the life of me loosen up the top bolt on the caliper bracket. I'm on my way to get a torch and hit it with some heat. It's soaking in WD40 right now, but if this fails, I'm not sure what I will do...leave the old bracket on? I'm so close to rounding the bolt.
- Been thanked: 4064 times
Wd40 is not a penetrating oil. Use PB blaster it Liquid a Wrench, or the infamous acetone/ATF mix if you like to cook meth.
You need to wire brush the bolts and apply this for three days at least to let it soak in. Ring the bolt heads with a hammer too. Patience patience and persistence. It took years to freeze up, take a few days to loosen it.
Deal with it now as you need to get this off when you need to replace rotors
Herb Goltz
- Year and Model: 04& 06 XC70, '12 s60
- Has thanked: 7 times
- Been thanked: 5 times
Make sure you use 6 point sockets-- I have had good luck with steady force using a 3 foot breaker bar.
If the head is buggered up when you get it off, buy a new one.
Good luck!
Good luck!
2012 s60 t5
2006 XC70
2004 XC70
2006 XC70
2004 XC70
jakeman1111
- Year and Model: v40
I had same problem with top caliper bolt. Tried every chemical loosening agent known. Final solution: Removed slide pins to allow removal of hydraulic portion of caliper. Doing so allowed me Saws-All access to bolt head. Using metal cutting blade (make sure spindle is fully turned to obtain room for Saw-All). Wire brush clean bolt flange to steering knuckle mating flange to allow for precise placement of cutting blade. Cut bolt head off and the remaining caliper part can be removed
Thats a nasty piece of work, Jake - well done..
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Wowsers...
I'm guessing the heat wasn't able to break that bond.
- 15 Replies
- 6407 Views
Last post by wizechatmgr
- 1018 Views
Last post by cn90
- 3019 Views
Last post by JimBee
- 2791 Views
Last post by FireFox31
- 27 Replies
- 6417 Views
Last post by volare
