1999 S80 alot of electrial doesn 't work
I purchased a 1999 S80 that had sit for two years with a dead battery. I was told everything worked when parked. Jumped started the car and radio, sun roof, A/C and blower fan did not operate. I also had 6 messages on the dash saying brake failure, power steering, failure trans failure, etc.... Should everything start working with a new battery installed?
I'm no S80 electrical expert - I'm having my own issues at the time, but whenever changing the battery you should cycle the lock/unlock buttons on the fob. A quick search will verify the veracity of this seeming bizarre (to me) procedure. (this one lists two common procedures and is pleasantly short and to the point http://volvoforums.com/forum/volvo-s80- ... ment-5646/ )
All the lights may be another issue however. I think I would try the disconnect the battery method first. Jumping cars nowadays is not always a simple, or safe, procedure.
- 1384 Views
Last post by Uree
- 37 Replies
- 5074 Views
Last post by wbrenegade420
- 241 Views
Last post by 122sPhil
- 580 Views
Last post by ossgrandi
- 1691 Views
Last post by JDS60R
