99 S70 broken door lock pin attachment point
v-45magna
Year and Model: 99 S70 GLT
Has thanked: 2 times
Post by v-45magna »
I am going through my weak lock actuators, removing the thermal resistor, yada yada yada. I happened to break one of the little white plastic ears that the door lock operating pin (the one that sticks out of top of the door panel) attaches to. If you haven't seen this part or dealt with it before, taking off and re-installing the bar requires the plastic 'ears' to flex inward slightly and spring back out. If it breaks, there really isn't a way to replace it with the entire assembly or I guess you go without the manual pin in the door.
I cleaned it off with an old toothbrush and Dawn soap, dried it, and super glued it, knowing full well it would just break as soon as I tried to reinstall the operating pin. Then I filled the void between the ears with Goop brand silicone. It stays flexible, and is waterproof. Because it was broken, I waited long after it cured (I gave it 24 hrs) before reinstalling the bar, hearing the tiny crack as the ear broke off again. But everything stayed in place. I'm not waiting for another one to break and I'm doing this with every door lock actuator as I go through them just as a precaution. Pics of the next one I did preemptively (right rear) are below for an example.
I have it clamped to reattach the cover after the motor mod here, but you can see the white plastic part at the center of the pic.
And here filled with silicone. Since this one wasn't broken to begin with, I only gave it about 45 minutes to cure. It just needed to be firm to put it all back in. I figure this strengthening measure will likely keep it from breaking indefinitely.
Hopefully this saves someone else from buying a latch assy.
