If a lug nut got stripped when a mechanic was putting on the wheel, what else needs to be replaced? I assume that the receiving end also got stripped.
Thank you
1996 850R Lug Nuts
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Nothing special.
- RussB
- Year and Model: '00 S70, '04 S60
- Has thanked: 3 times
What is stripped? The hex or the threads?
Note that they have lug BOLTS, not nuts. The hub is threaded M12x1.75
'00 S70, '04 S60 and the never ending quest for Stage Zero
- RussB
wackenhut wrote:I believe the threads. Would the hub need to be replaced too?
If the threads in the hub are stripped, then yes, the hub would need to be replaced. Your mechanic is a Gorilla!
- 1981 Views
Last post by jimmy57
- 1234 Views
Last post by tle1288
- 11 Replies
- 4393 Views
Last post by beigg
- 23 Replies
- 10654 Views
Last post by zupta82
- 1244 Views
Last post by packetfire
