I picked up a 1997 S90 dirt cheap because it needs work on the valve train.
The engine control module has DTC EFI-314 Camshaft position sensor signal. So I decided to replace the Camshaft position sensor first. I replaced the CPS with a new Bosch 0232101030. The engine will not start with the new CPS installed, but if I reinstall the old CPS it will start.
Any ideas before I declare the new CPS defective?
1997 S90 Won't start on new CPS.
- RickHaleParker
- Been thanked: 978 times
Active
Past
Past
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Want to sell it dirt cheap?RickHaleParker wrote:I picked up a 1997 S90 dirt cheap
I think there is a way to ohm check a CPS, but I've never seen any literature for newer vehicles.
- RickHaleParker
No 93Regina, I'm not frustrated with it. Matter of fact we are finding it a entertaining challenge. None of us have encountered anything like this before.
We have eliminated the possibility that the new CPS is defective by installing it on my C70, fired right up.
Tried the old CPS from the C70 on the S90, won't fire up. For some reason the S90 will only fire up on one specific CPS. What that reason is .... ????
Active
Past
Past
- 93Regina
Buy one from ebay, and take back the one your bought.: Volvo - 3547699RickHaleParker wrote:new CPS
Btw, Bosch 0232101030 is a Cam Position Sensor
- RickHaleParker
How did that slip by... No wonder you guys couldn't make heads or tails out of my inquiry.93Regina wrote:Buy one from ebay, and take back the one your bought.: Volvo - 3547699RickHaleParker wrote:new CPS
The DTC is EFI-314 Camshaft position sensor signal, not Crankshaft position sensor signal. I made corrections in my original post.
Good catch 93Regina.
Active
Past
Past
- 93Regina
I'm blind to this situation...so, did you check the gap between sensor and cam?RickHaleParker wrote:What that reason is .... ????
Everything you need to know: A position sensor just for the CAMs and CRKs...
- RickHaleParker
The gap between sensor and cam is fixed, no adjustment.
We how have a theory that could explain this never seen before behavior.
(1) The valve train problem is serious enough to keep the engine from starting.
(2) The defective camshaft position sensor is throwing off the firing of the coil packs.
(3) By seer coincident, the engine will sync well enough to run when both defects are present.
(4) When we correct the coil pack firing by replacing the camshaft position sensor, the valve train problem prevents the engine from starting.
Best theory we could come up with. We are going to correct the valve train problem and replace the defective camshaft position sensor and hope this theory is correct.
Active
Past
Past
- 726 Views
Last post by cn90
- 1777 Views
Last post by erikv11
- 856 Views
Last post by kahl
- 3034 Views
- 810 Views
Last post by MadeInJapan
