Sorry guys, i am. really in difficult position and cannot search the forum first but i will search when i wait a response.
The car is starting, and in couple of seconds it dies again. Pressing the gas pedal doesn't change anything.
Any idea?
S70 starting. And dying in 5 seconds
raykan
- Year and Model: 1998 S70 GLT => 236K
I was sitting in the car, it was running. All the sudden it died. I run it again, press the gas, it responded however it diedagain after i stop pressing the gas pedal.
After this time it s starting but stopping in a second. Like it doesnt get enough gas.
- Been thanked: 504 times
If you search forum, you will see that people recommend only BOSCH MAF.
About $150 or so.
For now, unplug the MAF until you get the new one.
When replacing the MAF, watch for that BIG O-ring seal.
About $150 or so.
IF this is a turbo car, and you have an induction leak in the tubing between the MAF and the TB, your MAF could be fine. Look for leaks, loose clamps, splits in the tubing.
Some of these can only be found be removing the induction pipe and inspecting out of the car.
raykan
That makes sense. I will check for the leak. I think i have to consider to change the o2 sensor since the engine light was popping up because of it for awhile.
Thank u every body for their time.
Change the MAF if you can't find any induction leaks, clear codes, drive for a bit. All of those codes can be caused by a bad MAF, it's not uncommon to get a bunch of codes when the car isn't running right
- 956 Views
Last post by misha
- 1343 Views
- 1902 Views
Last post by RickHaleParker
- 930 Views
Last post by NeilBisby
- 2049 Views
Last post by Bren
