The ECC is flashing lights on the REC and AC which I know from reading means that there are codes/faults.
Does anyone know if there is a way to get the codes without taking out the ECC? Please let me know if you can.
Thank you.
1996 850 ECC (Electronic Climate Control) light flashing
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Via obdII port,but you need to go to a dealer.
...or you can made yourself a flash code reader,because ECC up to V70 still produce flash codes.
Choice is yours.
Choice is yours.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
I would be disappointed if they don't.They are called "stealership" worldwide for a reason.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Been thanked: 4063 times
My Autel 802 reader nicely reads Volvo ECC codes. Right now about 200 on ebay or amazon
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I made a little homebrew code reader for the ECC unit. You need a few inexpensive components such as an LED, a switch, a resistor, and some wire. If you're into this type of DIY, it is fun and rewarding! I wrote up the a more complete description of the materials, circuit, use and interpretation of some of the ECC codes here:
https://www.matthewsvolvosite.com/forums ... 43#p251189
Once I learned what the error code was, I fixed one of the components that had failed:
https://www.matthewsvolvosite.com/forums ... 5&p=251432
Good luck!
Good luck!
- 11 Replies
- 6744 Views
Last post by maxi948
- 332 Views
Last post by AlanHMultiV70s
- 20 Replies
- 6165 Views
Last post by RickHaleParker
- 3473 Views
Last post by caliwagon
- 695 Views
Last post by Top Notch
